I have modified an existing model file of a photo-etched stainless steel plate, which is bent at an angle along a form line. I have two reference sets in my model, one of the flat plate (called FLAT_FORM) and one of the part after it is bent into shape (called CLAMP_IN_SITU). I want to create two drawing sheets, the first showing the reference set FLAT_FORM and drawing sheet 2 showing CLAMP_IN_SITU. Can somebody please explain how I would do this? From what I can see I can only select one reference set which will appear on all of my drawing sheets.
