TechnicalConsultant
- Mar 26, 2004
- 172
I am using version 18 and have a rather large 3d assembly. All the sub-assemblies are controlled using the ref set "solid" to keep any unwanted datums etc out of the upper level. However, occasionally when i open my upper level assembly the sub assemblies are not being displayed. They are loaded but the only way to display them in the upper level is to change them globally to entire part the n change back to SOLID. This works perfectly but i am curious to see if anyone else has had this problem.
Thanks in advance
Thanks in advance
