jghrist, thanks for your comments. It is not only when there is a deviation at a pole. If the spans lengths are not the same, even if the tension is, the worst case pole load will probably not occur when the wind is perpendicular to the line. Other software such as Poles 'n' Wires makes allowance for any wind directions and calculates the worst case pole load. But I am using sag10 and there is no provision for that. I was hoping another sag10 user had a suggestion about how to handle it.
