When sending large ProE files, using ZIP can reduce their size to about 50% or more. Sometimes this is not enough.
A simple solution is to use the INSERT mode. Drag and drop the INSERT HERE arrow to one of the first features. Now all features after the INSERT HERE will be suppressed.
The file size is now dramatically less then even with ZIP!
When the receiver gets the file, they simply cancel the INSERT mode or just drag the INSERT HERE arrow to the bottom of the Model Tree.
Steve
Steve
