Hi NDVermin.
Pneumatics is not the solution for you. That's why I asked just UP? DOWN? or in between? You can, of course use pneumatics for in-between but it more than triples the cost since you need special valves and scales and etc., etc.
The Bag-O-Steppers Mint showed you is probably the best type solution. Yes, the controls are a bit involved and will cost considerably more than those cheap steppers. Your wish for them all to move at once considerably increases the cost of the electronics, I'd say by about a factor of... a hundred (100).
The height resolution desired will also greatly affect the cost of the solution.
Can you describe what this will be used for? It would help us, help you, determine the best solution.
We still have no idea what:
1) Forces will be involved.
2) What environment this will be in. Under water? Outdoors? Clean room?
3) What speed the blocks need to move at.
4) What ambient temperature.
5) Speed of motion.
6) Desired control input. List? Dynamic? Surface profile?
7) What power is available.
8) Position resolution
9) Actual block dimensions.
10) Block material
11)
12)
13)
20) Special considerations; sterilizable?, hazardous atmosphere? Portability?
Keith Cress
kcress -
