Recommendation for windshield rain sensor
Chancy99
Computer
Hi All -
Can anyone recommend a source for a windshield rain sensor ? Preferably one that doesn't require a 10,000 unit purchase :)
I'll take pretty much any technology, resistance, refraction, whatever. I just want to retrofit an auto-trigger for the wipers on our cars ... Interfacing to a small microcontroller shouldn't be too much of a worry. One pin for the output relay, one for an enable switch and one or two for the sensor input.
Thanks -
Dean.
This may be a stupid idea but what about that conductive tape that alarm companies put on glass to tell if the glass has been broken, you could put a couple of small pieces together and if water was present it could complete the circuit like a switch.
One option would be to use a camera poking out of the windscreen, typically behind the rear view mirror. This is used to detect drops on the windscreen. Cheers
Greg Locock
You could try the MLX90255. It is a linear array which is suitable for automotive, the drawback is you would have to interpret a bit-stream to get the output information. I don't know if you already thought about this? But it's an appropriate sensor and you can buy them in single pieces I think at Melexis.com
