What jurisdiction governs? Building codes usually require 3" minimum clearance to reinforcing if concrete is to be placed against earth. Where is the bottom mat in the design? Nine inches seems excessive.
Standees, as stated by others, have a problem sitting on soil/sands. Dobies (concrete blocks w/tie wire embedded) are usually better for bottom mats. They are cheap and readily available.
There is also a potential for corrosion to travel up steel standees right to the rebar. The increased cross section necessary for tall standees would add to this problem. In wet or corrosive soils some specs call for plastic, coated steel or stainless steel standees if the designer elects not to allow dobies.
