Re-attaching Dimensions in Drafting
Jamziee
28
Hi Guys,
If a dimension becomes dettached from some geometry on a drawing, is there a way re-linking the dimension without deleting it and inserting a new one?
I've looked at the NX2 help files and they seem to suggest using the 'Feature Parameters' on the Drafting Annotation toolbar, but I cannot seem to get it to work.
Any advice would be much appreciated.
Many thanks,
Andy.
(Using: UG NX2)
Design Draughtsman
Biomet Ltd
Edit->Drafting Object Associativity
By default the Edit Dimension Associativity icon is selected, so pick the leader you want to reattach, and then the entity you want it attached too.
-Dave
Everything should be designed as simple as possible, but not simpler.
