Re-attach a detached drawing
vikdayal
CA
Guys ... can anyone please tell me the best way to re-attach a detached drawing so that it acts as a normal drawing file with all the references and so that I can right-click on the assemblyin a view and open the assembly file.
regards
vik
SW05 you can RMB the Sheet Format and click Load model. It then loads the model. Then you must re-save the drawing.
Scott Baugh, CSWP [pc2]
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
Thanks a lot Scott, but can we do it in Solidworks 2004. What can be done in Solidworks 2004. I would highly appreciate your response.
Vik
Sorry about being such a fool, I should have tried it and yes sir it does work in SOlidworks 2004 as well. You just have to load the model by right clicking one of the views in the Design tree and then saving as a drawing (not detached one this time) and it is fine.
Thanks a lot Scott !
