I m designing RC frame (one storey). It is a moment frame so column - beam reinforcement details are important.
I have to draw reinforcement details for column - beam connection and Im kinda lost - im doing this for the 1st time and I dont have any examples.
Should I leave straight reinforcement from the columns and bent beam rebars at the end and connect them to column rebars (case 1)?
or should I bent column rebars at the top into the beam (case 2) and leave beam reabars straight?
or should I do combination of both cases?
I also dont know what to do with each rebar at the top of a column since there are so many of them. If there was another storey above Id leave column rebars straight, but since I have one storey, i m not sure.
I m also not sure how to do this since its a 3d frame. I have another beam from other direction too. so im confused which rebars to bent.
What is the most sufficient and simple way to go there? Any detail, photo would be great...
