T_Bat
- Jan 9, 2017
- 213
Hello everyone,
I have what may be a simple question. I'm looking at designing some moment connections for an Intermediate Moment Frame. I'm between using and RBS or WUF-W connections (I've asked for fabricator input). One thing I've noticed is that the design examples I've found don't check the beam flange's ability to carry the flange force from the design moment. For example on a standard R=3 direct welded moment connections with a bolted shear tab I always verify that the beam flanges will be able to actually carry and transfer the flange forces resulting from the design moment to the column. The RBS example in AISC 341-10 does not consider this failure mode. This may be, in part, since the web of the beam is CJP welded to the column. If a bolted web connection is used in an RBS wouldn't the flanges be required to develop the couple from the "probable maximum moment"? Same question applies to the WUF-W.
Hopefully this is a simple answer and I just am missing something.
Thanks in advance!
Thanks in advance!
