Hello every one,
I'm new at FEA Advance Simulation in NX9.
I have two parts one ' A ' is fixed and the other ' B ' is on top of it.
I made some RBE2 connections between the two parts.
At this time I can solve my solution.
But the part ' B ' is bending in the middle of it. I want it to lay down on the part ' A ' to see deviation of the part ' A ' when it support the weight of the part ' B '.
I've been told to use RBE3 connections between the two parts because I don't want them to be rigid...
I connected the two parts with one nod on each parts.
The solver in .f06 give me fatal error :
*** USER FATAL MESSAGE 2038 (RBE3D)
RBE3 ELEMENT 51 IS SINGULAR.
USER ACTION: ADD MORE DOFS TO THE CONNECTED POINTS TO INSURE THAT THEY CAN CONSTRAIN ALL 6 RIGID BODY MODES
OF THE ELEMENT.
I tried to manually play with different DOFS configurations in mesh associated Data. I cannot find what is wrong with my RBE3.
Do I use the wrong connection ? Maybe it is a problem my nods are not really co linear?
I tried to find out what I'm doing wrong in this forum and I found nothing.
I hope you can help me folks to find what is my problem and BTW the your eng-tips forum are very helpfuuuulll!!!!
OF THE ELEMENT.
