I would like to modify my earlier comments as follows:
In order to arrive at a constant velocity, the jet plane must accelerate and there would be forces associated with that acceleration. However, once a constant velocity has been reached, there is no acceleration, which means the system is in equilibrium.
I now believe that the correct answer to the question is 1/sinθ, as you have shown on the solution at the left.
EDIT: But wait a minute...that can't be correct, because as θ approaches zero, i.e. level flight, W/sinθ increases without limit. If the jet plane is in equilibrium after it reaches constant velocity, then T - R = 0 and the answer to question 4. is 0.
Don't hang your hat on this analysis. I think we need the help of an aeronautical engineer to solve this problem. I believe I flunked the exam. Help!!!
BA
