athomas236
I am involved in an ultra supercritical power project in for which the equipment will be supplied by a Chinese EPC contractor.
The Project will consist of 2x700MW coal fired units with boiler steam conditions of 260 bar / 605C / 603C with a main steam flow of 2000tonnes/hour.
At the moment, we are discussing the maximum rates of load change (up and down) and the contractor is offering the following:
1.5%MCR/minute in load range between minimum continuous load without oil firing(approx 35%MCR) to 50%MCR
2.0%MCR/minute in load range from 50%MCR to 100%MCR.
These rates appear to be very slow and appear to contradict one of the claimed advantages of supercritical boilers over drum type, namely, higher ramp rates.
Based on published literature and experience on two other supercritical projects (420MW, 250bar / 570C / 570C) and 660MW / 250bar 570C / 570C), I would have expected ramp rates of 5%MCR/minute in the load range above approximately 40-50%MCR.
I would appreciate any comments or advice that can be offered on maximum ramp rates for ultra supercritical boilers.
athomas236
