400 deg.C is rather hot! Last time I checked my steam tables, water boiled at 100deg.C.
I mention this because there will be a (small) "jacket" of vapor around the wire, at least at the inlet side of the coolant tank. Considerably lower h.t. coefficient if it is effectively insulated for a period of time.
Also, remember the total residence in the tank is
0.65m/30(m/s) = 0.022 sec.
Is any air, even the smallest amount, entrained on the wire as it flies into the coolant tank. Yes, it is. Down goes the h.t. coeff. again.
If it weren't for the phase change of the water, I would intuitively line up with "quark", but there is too much going on for me to be very comfortable with that kind of bulk analysis in this case.
I think that a lumped parameters analysis could also easily get into errors of oversimplification of the convective film coefficent.
Calculating a few values of Biot number will validate/invalidate "quarks" analysis; IF you think you know "h".
I'm just too tired, or lazy, or unimaginative to do it.
