Yeah, I do often _think_ 'looks about right'.
Before I _write_ 'looks about right', I run a few numbers.
Yes, any engineer should be able to calculate the forces and the stresses. Even I can do that.
I suggested copying a successful design so you start with _geometry_ that's about right.
I've seen lots of projects fail, yes including from homebrew ratchet designs, because a designer was too proud to copy, or at least do some intelligent comparative anatomy and reverse engineering.
OR, if you're intending to use a bunch, see if someone like J.H.Williams would be willing to tool up and supply your ratchet assembly as a component.
Mike Halloran
Pembroke Pines, FL, USA
