Randomize surface colors in a CATPart 1
PedroReg
PT
Hi Guys
I have recently understood the power of macros and have been trying to learn a few things.
I work a lot on the GSD, so I tried to create a macro to randomize the surface colors (only the default) that are displayed on my screen.
Unfortunately, I couldn't do that.
Here is the code that I tried:
Sub CATMain()
Dim vis As Variant
Set objSel = CATIA.ActiveDocument.Selection
objSel.Search "CATGmoSearch.Surface.Color='(243,254,177)',scr"
Dim I As Integer
Dim r As Integer
Dim g As Integer
Dim b As Integer
For I = 1 To objSel.Count
r = I * 5
g = I * 10
b = I * 15
If r > 255 Then
r = r - 255
End If
If g > 255 Then
r = r - 255
End If
If b > 255 Then
r = r - 255
End If
vis = objSel.Item(I).VisProperties
vis.SetRealColor r, g, b, 0
Next I
End Sub
Here's the following questions that I have:
1. Can I separate the selections I get from my search?
2. Why is " vis = objSel.Item(I).VisProperties " getting an error?
Thanks in advance
you need to put set in from of vis = objSel.Item(I).VisProperties
i.e. set vis = objSel.Item(I).VisProperties
regards,
LWolf
Hey LucasC,
Thanks for your reply!
I tried to follow your thread, I came up with this:
Sub CATMain()
Dim vis As Variant
Dim objsel As Selection
Set objsel = CATIA.ActiveDocument.Selection
objsel.Search "CATGmoSearch.Surface.Color='(243,254,177)',scr"
Dim mySurface As HybridShapeSurfaceExplicit
Dim I As Integer
Dim r As Integer
Dim g As Integer
Dim b As Integer
I = 1
For Each mySurface In objsel
r = I * 5
g = I * 10
b = I * 15
If r > 255 Then
r = r - 255
End If
If g > 255 Then
r = r - 255
End If
If b > 255 Then
r = r - 255
End If
objsel.Clear
objsel.Add mySurface
Set vis = objsel.VisProperties
I = I + 1
Next
End Sub
The code is currently give me erros on the following line "For Each mySurface In objsel". I believe it's because the "mySurface" is a HybridShapeSurfaceExplicit and the "objSel" is a Selection.
Any tips?
Hi LWolf,
I'm sorry for missing that one! (rookie mistake)
However, it comes with the same error "Object doesn't support this property or method"
Any tips?
for each loop doesn't work on selections. use
Code:
dim i as integer
for i=1 to objsel.count
[indent]...[/indent]
next
regards,
LWolf
also, if you are working in the selection, you cannot clear it downstream in the code...
regards,
LWolf
That's what I have on my first code and still does not work
I need to separate the selecions from my search, i just don't know how.
Thanks in advance
this works :)
Code:
Sub CATMain()
Dim r As Integer
Dim g As Integer
Dim b As Integer
Dim i, k As Integer
If objsel.Count > 0 Then
    ReDim SelArray(objsel.Count - 1)
    For k = 1 To objsel.Count
        Set SelArray(k - 1) = objsel.item(k).Value
    Next
    objsel.Clear
    For i = 0 To UBound(SelArray)
        r = i * 5 + 100
        g = i * 10 + 100
        b = i * 15 + 100
        If r > 255 Then r = r - 255
        If g > 255 Then r = r - 255
        If b > 255 Then r = r - 255
        objsel.Add SelArray(i)
        objsel.VisProperties.SetRealColor r, g, b, 0
        objsel.Clear
    Next i
    Else
        MsgBox "Nothing selected"
    End If
End Sub
regards,
LWolf
You may want to explore a different search parameter. I think ,scr will only search what visible on your screen as you are viewing it. in other words, if you are zoomed in on one area, only that little bit will be captured when the macro is run.
Lwolf you are a Legend
Thank you so much!!
I just need to tweak the R, g and b equations
Thanks for your patience
