Setting body color RGB with an array
I'm trying to develop some code that changes all the part bodies in a CATPart with a group of RGB values. I'm trying to do this with an array but its not functioning correctly. It cycles through the structure and selects each body as intended but does not change the color. I believe its the way I have the values defined in the array:
Dim RGB(21)
RGB(0) = "234,234,234,0"
RGB(1) = "30,49,130,0"
RGB(2) = "147,155,161"
...etc
...For next
Set vis = sel.VisProperties
vis.SetRealColor RGB()
RE: Setting body color RGB with an array
Hi LucasC,
sub SetRealColor (long iRed, long iGreen, long iBlue, long iInheritance) expects 4 long values, but you are providing 1 string value. Change your array like this:
RGB(0) = Array(234, 234, 234, 0)
RGB(1) = Array(255, 255, 255, 1)
and then call it in a loop this way: vis.SetRealColor RGB(0)(0), RGB(0)(1), RGB(0)(2), RGB(0)(3)
Tesak
http://scripts4all.eu/txtoncurve/ - Text along a curve for Catia V5
No luck with :
Dim RGB(21)
RGB(1) = Array(30, 49, 130, 0)
RGB(2) = Array(147, 155, 161)
'...etc
Dim visprop As Variant
Dim sel1 As selection
Dim Part1 As Part
Set Part1 = CATIA.ActiveDocument.Part
Set sel1 = CATIA.ActiveDocument.selection
Dim myBody As Body
For Each myBody In Part1.Bodies
sel1.Clear
sel1.Add myBody
Set visprop = sel1.VisProperties
visprop.SetRealColor RGB(0)(0), RGB(0)(1), RGB(0)(3)
Next
What kind of error do you get? Anyway, you have a mistake in the last line, you are calling SetRealColor with 3 arguments only.
Tesak
There is no error, it cycles through all the selections without changing the color.
Change it like this:
CODE --> VBA
Dim myBody As Body
Dim i As Long
    sel1.Clear
    sel1.Add myBody
    visprop.SetRealColor RGB(i)(0), RGB(i)(1), RGB(i)(2), RGB(i)(3)
    i = i + 1
Next
Tesak
Yes, I noticed I had the RGB item index mis-labeled and it colored all the bodies the same, which made me realize i needed to index the RGB +1
How can I make it start over if the number of part bodies exceeds the array value count?
thanks in advance I'm still a beginner.
To start over use this:
CODE --> VBA
If i > Ubound(RGB) Then i = 0
i = i + 1
Tesak
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Close Box
Join Eng-Tips® Today!
Join Us             Close
