Hey everyone,
I've got an interior build out I'm assisting with and we need a floor surface raised around 16" to 18" inches (think like a raised access floor). The existing floor is a steel composite floor system (3rd story). My plan was to use light gauge framing with sheathing on top to form the elevated floor - similar to how you may frame auditorium/theater seating. I'll add some diagonal studs every so often for stability.
Before I go too far down this road detailing/designing, has anyone got a better system they've used? I'm also toying with using wood. It can't be a typical data center type pedestal floor because it's a kitchen and will get mopped or even potentially sprayed down for cleaning so it needs to be reasonably water resistant.
