Electric locos pick up high voltage from an overhead catenary. The return path is through the wheels to the rails which complete the circuit. At least, that's what I understand.
But if the wheels are isolated from the rail momentarily (eg leaves on the line!), the circuit is broken and the wheels are at the same potential as the overhead wire. Well that's OK, but the wheels have to be isolated from the frame of the loco - otherwise the whole loco (and the train itself) is at the supply potential. This would mean that opening the doors of a carriage would not make your day.
But how do you isolate the wheels from the axles, the axles form the gearbox, traction motors etc? - while maintaining a very high level of mechanical integrity.
In the UK I believe that 15 kV is the standard voltage, and that 25 kV exists elsewhere. So the voltages are not trivial, but folks don't seem to get frazzled - so how is it done?
I'll drive to work until someone explains the solution!
