I have a 4/12 roof conventionally framed with 2x6 (actual) rafters at 24" O.C., 2x8 ceiling joists, and a 1x6 ridge board. They want to make one side of the ceiling vaulted to follow the pitch of the existing roof rafters so they would have to remove the ceiling joists on one side. Obviously when removing the ceiling joists on one side you increase the thrust to the wall from the rafter. There is an interior wall about mid span that was supporting the ceiling joists and still is supporting the o=one side of ceiling joists to remain.
If I design a pony wall to extend above the interior wall and support the ridge (or very close to it) will this greatly reduce or even eliminate the thrust from the rafter at the top plate? The way I look at it is if you had a ladder against a wall and you permanently supported or fixed the top end then the bottom end wouldn't be able to slip out right? Am I missing something here?
