I know this shouldnt be difficult, but what are the basics for designing a beam raft, and at what point do you decide that normal strip footings is not the way to go and a raft is better?
Say for a typical 2 storey house, average loads below loadbearing walls are say 75kN/m. If your safe ground bearing pressure is 150kPa, a footing width of only 500mm will suffice. Now, if the safe ground bearing pressure is say 50kPa, a footing of 1.5m a meter wide is required.
Would a beam raft be more economical in case 2?
Now for the design basics, should I ensure the beams are below load bearing walls, and what width should these beams be? I have read that the beams in the raft must be sized so that the load from the walls above does not exceed the safe ground bearing pressure. So in this case, also 1.5m wide. What is the benefit then of a raft in Case 2 if the beams are as wide as a reinforced strip footing would have been? I am definitely missing something, and hence this thread.
