H
hamidzub
Guest
i am trying to assemble a rack & pinion arrangement in which rack is to be stationery, however the pinion would translate due to motor attched at its centre because of relative motion. But i cant fix this as the mechanism requires the slider joint for rack.
Can anyone know how to fix the problem. or some alternative solution.
Best Regards
Best Regards
