R18 loading user workbenches
catiauser4
Automotive
CA
i've created a user workbench in V5R18, but after closing catia and opening again, i can no longer load the workbench. it still shows up in the customize window, but when i load it either from the workbench toolbar, or from the start menu, nothing happens. switching to other workbenches works just fine.
any ideas?
thanks very much,
mike
thanks for your reply.
i'm not sure what service pack level it is, how would i determine that?
that is what i first tried, but i didn't see anything about service pack. here is what i get:
CATIA(R) Version 5.18 (C)....
Build Day: 06-20-2007.21.12
and the rest is about the patents and so forth.
does that help?
Hey Mike
you can find out what sp you are useing by going into Catia> tool>Software Management..it will be in the first tab which is General
The Help section reflects the same information that is in the Software Management tool. (which many users don't have immediate access to) I guess you are probably at GA release.
Delete your CATSettings (after you make a backup somewhere) and re-start Catia. You will have to re-create the user workbench. If that solves your problem, it was the issue. If not, reload your CATSettings from backup, and contact the Catia reseller/VAR.
Catia Design|Catia Design News|Catia V5 blog
