So, I have a long history of ASME code work but I got hit with a question that I am not positive of my answer.
ASME Vessel installed in Texas. Owner requires this to be treated as a "code state" even when it is not. Vessel is a column with a nozzle protruding to the inside some 12". Someone wants to weld fittings to the end of that nozzle to divert the flow inside the vessel. While I would not normally consider this to be a pressure boundary, if that nozzle clogs, this could be pressure retaining. Would welding to this nozzle require an R Stamp shop and hydro?
