athilatt;
In basic terms, QW-200.4 (b) describes the use of multiple PQR's to support a multi-process WPS provided the coupon for the PQR is ½” or greater in thickness. Yes, this paragraph can be used for root deposits, as one example, where one PQR with a coupon at least ½” in thickness was welded with one or more processes recorded could be used for the root up to 2t thickness, where a second PQR recorded using another one of the processes listed in QW-200.4 (b) is completed to fulfill the base metal thickness qualification for the WPS used, and both of these PQR’s support a multi-process WPS.
