Have a torsional connection at the top of a concrete footing (supporting a relatively light item with a lot of surface area). Therefore, wind is my evil loading...See attached sketch.
Torsional moment is 9.5 k-ft - not large, but trying to get an estimated weld length has been difficult. The only way around it, that I could see, was to flare "stiffeners" from the HSS section to get the required weld length.
Basically (3) things I am unsure of:
1. Now that I have introduced these elements, is it even worth checking their capacities? If yes, is there a rational procedure floating around? My intuition says this small loading can be handled by inspection with not much additional analysis.
2. I am concerned that as the HSS begins to torque there will be an uneven distribution of stress in the welds, maybe causing the 'front-loaded' welds to crack. Any ideas in configuring this connection in a different manner?
3. I can't find a prequalified weld between the HSS and the base plate. The closest I could find was a flared weld, but it didn't show the HSS bearing on the plate to be welded to.
In Russia building design you!
