That's why I excluded almost half of the Master Plan. As I mentioned, ISO 5459:2011 Datums and datum systems are 81 pages and 198 swiss francs or 210 US Dollars, which by itself is more that the ASME Y14.5 specification, currently $185.
This is referring only to ISO 14638:2015(en) Geometrical product specifications (GPS) — Matrix model, which does not include drawing management. It does include inspection methods, which I tried to estimate an exclusion of, but with ISO datum referencing alone costing more than the entire ASME Y14.5 Dimensioning and Tolerancing, it is hard to say that any comparison will put them on even footing in terms of cost.
More insidious, there are others required, that are not in this list; ISO 5458:1998(en)
Geometrical Product Specifications (GPS) — Geometrical tolerancing — Positional tolerancing, requires ISO 14660-1:Not Released), Geometrical product specification (GPS) — Geometric features — Part 1: General terms and definitions, which has already been superceded by ISO 17450-1:2011 Geometrical product specifications (GPS) -- General concepts -- Part 1: Model for geometrical specification and verification.
While I can understand why contributing employees of big companies serving on the Y14.5 committee would be compelled to 'harmonize' with suppliers working on the ISO GPS committees, ISO doesn't immediately seem attractive to emulate in any way.
Below is the list from the Master Plan, items pertaining to drawing specification are bolded, but these are only from the Master plan and do not include all drawing creation GPS standards.
[1] ISO 286-1:2010, Geometrical product specifications (GPS) — ISO code system for tolerances on linear sizes — Part 1: Basis of tolerances, deviations and fits
[2] ISO 286-2:2010, Geometrical product specifications (GPS) — ISO code system for tolerances on linear sizes — Part 2: Tables of standard tolerance classes and limit deviations for holes and shafts
[3] ISO 463:2006, Geometrical Product Specifications (GPS) — Dimensional measuring equipment — Design and metrological characteristics of mechanical dial gauges
[4] ISO 1101:2012, Geometrical product specifications (GPS) — Geometrical tolerancing — Tolerances of form, orientation, location and run-out
[5] ISO 1660:1987, Technical drawings — Dimensioning and tolerancing of profiles
[6] ISO 1829:1975, Selection of tolerance zones for general purposes
[7] ISO 1938-1, Geometrical product specifications (GPS) — Dimensional measuring equipment — Part 1: Plain limit gauges of linear size
[8] ISO 2692:2006, Geometrical product specifications (GPS) — Geometrical tolerancing — Maximum material requirement (MMR), least material requirement (LMR) and reciprocity requirement (RPR)
[9] ISO 3040:2009, Geometrical product specifications (GPS) — Dimensioning and tolerancing — Cones
[10] ISO 3274:1996, Geometrical Product Specifications (GPS) — Surface texture: Profile method — Nominal characteristics of contact (stylus) instruments
[11] ISO 3650:1998, Geometrical Product Specifications (GPS) — Length standards — Gauge blocks
[12] ISO 4287:1997, Geometrical Product Specifications (GPS) — Surface texture: Profile method — Terms, definitions and surface texture parameters
[13] ISO 4288:1996, Geometrical Product Specifications (GPS) — Surface texture: Profile method — Rules and procedures for the assessment of surface texture
[14] ISO 5458:1998, Geometrical Product Specifications (GPS) — Geometrical tolerancing — Positional tolerancing
[15] ISO 5459:2011, Geometrical product specifications (GPS) — Geometrical tolerancing — Datums and datum systems
[16] ISO 8015:2011, Geometrical product specifications (GPS) — Fundamentals — Concepts, principles and rules
[17] ISO 10360 series, Geometrical product specifications (GPS) — Acceptance and reverification tests for coordinate measuring machines (CMM)
[18 ISO 11562:1996, Geometrical Product Specifications (GPS) — Surface texture: Profile method — Metrological characteristics of phase correct filters
[19] ISO 12085:1996, Geometrical Product Specifications (GPS) — Surface texture: Profile method — Motif parameters
[20] ISO 12181-1:2011, Geometrical product specifications (GPS) – Roundness – Part 1: Vocabulary and parameters of roundness
[21] ISO 12181-2:2011, Geometrical product specifications (GPS) — Roundness — Part 2: Specification operators
[22] ISO 12780-1:2011, Geometrical product specifications (GPS) — Straightness — Part 1: Vocabulary and parameters of straightness
[23] ISO 12780-2:2011, Geometrical product specifications (GPS) — Straightness — Part 2: Specification operators
[24] ISO/PAS 12868:2009, Geometrical product specification (GPS) — Coordinate measuring machines (CMM): Testing the performance of CMMs using single-stylus contacting probing systems
[25] ISO 13385-1:2011, Geometrical product specifications (GPS) — Dimensional measuring equipment — Part 1: Callipers; Design and metrological characteristics
[26] ISO 13385-2:2011, Geometrical product specifications (GPS) — Dimensional measuring equipment — Part 2: Calliper depth gauges; Design and metrological characteristics
[27] ISO 13565 series, Geometrical product specifications (GPS) — Surface texture: Profile method; Surfaces having stratified functional properties
[28] ISO 14253 series, Geometrical product specifications (GPS) — Inspection by measurement of workpieces and measuring equipment
[29] ISO 14253-1:2013, Geometrical product specifications (GPS) — Inspection by measurement of workpieces and measuring equipment — Part 1: Decision rules for proving conformity or nonconformity with specifications
[30] ISO 14405-1:2010, Geometrical product specifications (GPS) — Dimensional tolerancing — Part 1: Linear sizes
[31] ISO 14405-2:2011, Geometrical product specifications (GPS) — Dimensional tolerancing — Part 2: Dimensions other than linear sizes
[32] ISO 15530-3:2011, Geometrical product specifications (GPS) – Coordinate measuring machines (CMM): Technique for determining the uncertainty of measurement – Part 3: Use of calibrated workpieces or measurement standards
[33] ISO/TS 15530-4:2008, Geometrical Product Specifications (GPS) — Coordinate measuring machines (CMM): Technique for determining the uncertainty of measurement — Part 4: Evaluating task-specific measurement uncertainty using simulation
[34] ISO/TR 16015:2003, Geometrical product specifications (GPS) — Systematic errors and contributions to measurement uncertainty of length measurement due to thermal influences
[35] ISO 16610 series, Geometrical product specifications (GPS) — Filtration
[36] ISO/TS 23165:2006, Geometrical product specifications (GPS) — Guidelines for the evaluation of coordinate measuring machine (CMM) test uncertainty
[37] ISO 25178-601:2010, Geometrical product specifications (GPS) — Surface texture: Areal — Part 601: Nominal characteristics of contact (stylus) instruments
