"DISPSILH" in 2006
ccable
GB
In AutoCAD 2000 DISPSILH=1 used to remove the display lines on a cylinder. This does not seem to be the case in 2006, the lines are remove when plotting but not in display any ideas. Thank You
Thanks Borgunit, not too bothered about plotting I just want the display to be smooth and without facets, clients often sit over me whilst I'm modelling and it spoils the effect!!
Is the cylinder a solid rather than a surface?
Did you also use the "hide" command?
