We a reproducung a part for a customer that is two pieces bolted together as an assembly. The mating surface of each part is flat w/in .0003". The surface opposite both of the mating surfaces is parallel w/in .0008".
When the parts are bolted together, we use four bolts torqued to 185 in/lbs. The problem is that the overall parallelism of the assembled and bolted parts goes to .0035-.0040"!
The Design Engineer from the customer mentioned the "clamshell effect". This makes logical sense when you look at the parts as the four bolts are grouped near each other and poorly placed for uniform compression. In addition to this, the mating surfaces don't make a complete surface across the entire part and the bolting is all on one side.
When the bolts are at 50 in/lbs, the overall parallelism is .0005". At 100 in/lbs, the parallelism is .0012". At 150 in/lbs the parallelism is .0035". By compressing one side of the part, the other side spreads apart.
The attached jpg shows the approx location of the four bolts (blue) and the mating surface area (red).
Has anyone heard of this before? Is there any information on this?
Thank you,
kidvb
Thank you,
kidvb
