If this scenario where submitted to me for review, I would disallow any credit for storage or Tc decrease for wetlands, unless storage volume where provided and flow was routed through it. The reasons?
1) You are using this flow to design a detention basin downgradient. You must err conservative. Why not divert the outflow around the basin? Careful though; if this is a perenial stream, then it is waters of your state or province and therefore (in the US) under USACOE juristiction. You can't just divert it.
2) As previously pointed out by lsp01, during times of flood flows, this area will be full (or very soon full) and provide little storage...unless you can demonstrate it through stage storage data. I would not necessarily require survey points, but it would be on you to show storage, so I don't see how else you would do it.
3) As touched on by bltseattle, only if the wetlands has a culvert outfall could you really claim a significant decrease in Tt. Weir flow over a berm could be analyzed, but you will find that instantly and with very little head (far less than a foot for all but the largest watersheds) the peak out will equal, or indeed exceed the inflow. Agian, if there is significant storage, you could see a time lag, but I would insist on seeing it routed.
4) A higher C value through wetlands would have to be shown through hydrogeologic analysis. Why not use SCS methods? There is allowance for soil type, land coverage and ponding built in to SCS methods.
