Given a vaporizer with an external sight glass providing indication of liquid level in vaporizer, it can be observed that on sudden loss of vaporizer pressure, that the liquid in the sightglass boils with liquid swell occuring which lifts the liquid in the sightglass. The appearance of the liquid is that it is foamy - much like opening a soda bottle. The question is what is the net affect of this boiling relative to what the liquid dP instrument will indicate as a liquid level. The arguments are that: 1) the boiling reduces the density (SG) of the liquid resulting in an indicated liquid level in the sightglass lower than it actually is in the vaporiser, 2) that the pressure of the vapor displacing the liquid results in a greater level in the sightglass than actually exists in the vaporizer or 3) that both are occuring. If both occurs, which is more pre-dominate?
Any ideas or comments will be appreciated The more you learn, the less you are certain of.
