Quick release pin
LACHANDARA
IE
Have attached a photo of a pin off a machine it basically slides through a bushing and holds a slide in position.
Can't seem to find one anywhere, on RS or misumi, if anyone knows where to find one, would be appreciated roughly 10mm in diameter can make the
bushing to suit.
Thanks,
Frank.
 http://files.engineering.com/getfile.aspx?folder=38a6d73b-ef9c-4113-ba40-262f7c34ba92&file=20150502_130709.jpg
LACHANDARA,
Those things also are available from Carr Lane.
JHG
LACHANDARA, from your mention of RS are you UK based? That may impact which sources you can easily use. I think Pip Pin was a common term for them in the UK.
Thanks for your reply's guys, yes I'm UK based so can't deal with McMaster carr, but speciality fasteners.co.uk seem to have what I need, so thanks for that Kenat.
Regards.
