I'm designing a stabilizing hitch pin for trailer and hitch applications, everything is good to go except my supervisor would like it to be cross drilled near the end so that a locking pin may be used. My problem with this is that I think somebody could just come by with a hammer and knock the end off fairly easily. I've attached a picture to allow better understanding. The diameter of the hole you see is 5mm. there is another hole through the center of the top view, which is illustrated with the red lines shown. It also has a diameter of 5 mm. The rest of the dimensions of outer and inner screw thread diameter and distances should be in the picture I've given. From my understanding and just an estimate, there will basically be four sectors connecting the main body of the pin, to the part after the 2 cross drilled holes. The centers won't be connected at all. Each sector is estimated at having an area of around 9-12 mm^2. Could somebody please help me determine which force acting downward in the Y-direction from the end would break off this end piece? Any help is greatly appreciated.
