Question on modelling
  • Thread starter Thread starter firedamage
  • Start date Start date
F
firedamage
Guest
I am doing shaft modelling,
I wonder what is 2x45 degreex0.5 and m60x1.5 mean? I have
circled them in red colour.
And what is the height for the relief on the shaft?
I dint see any indication of height of relief on the
shaft.
Thank you.
06_044756_1.png">
2 x 45 deg X 0.5 could mean a Chamfer / Setback of 0.5 mm
angled at 45 deg; 2 nos. One at the marked location and
the other at the opposite end. This is not the standard
practice.
M60 x 1.5 means: Metric thread to designation M60 (60mm
OD)
with a pitch of 1.5mm. Generally pitch is mentioned for
Fine pitch threads.
Generally depth of relief is not stated in a drawing to
reduce the clutter. You may consider a dimension of 0.2
to
0.5mm deep. However, standards for relief exists.
Edited by: SRINIVASANIYER1
With respect, I would suggest that you take an engineering course or ask your supervisor for explanations of engineering basics. I hope nobody has asked you to make this.
anyway M60 x1.5 is a metric thread on 60 dia shaft with 1.5 pitch
2 x 45 X0.5 is saying there are two chamfers with a 45 degree cut 0.5 long, the draftsman is leaving it up to you to find the other one, I expect its at the other end of the shaft.
THank you
Edited by: firedamage
I am taking enginnering course now..However now is summer
break,so i try to learn pro/E my self..
Is it here?
Thanks.
i expect so, although it looks bigger thatm 0.5
at the shaft end rite?
Is it using the round tool or chamber tool to create the
relief?
Thank you.
I appreciate all the helps.
Its a great design if you want to buy the genuine auto parts then must visit the site .
Its really a nice design.
