Pat's response is because you don't show us you understand the material and ask a very general question.
so too berkshire's (so he gives you a link to the material).
if you're saying you've read the material but don't "get it", i'd suggest starting with an earlier lecture and see if that helps. maybe if you ask a specific question about the derivation, maybe someone will give you a nice response (but don't count on it !).
assuming you know the material, and you're asking is it applicable to propeller drag analysis, i'd point out the initial assumptions "invisid, incompressible" fliud. i'd suggest that flow around a propeller is not incompressible (tip speeds are often close to mach 1), and so it probably doesn't apply (unless they derive a compressible version later in the lecture.
