stonebrook2003
hello, everyone
My problem is related to refrigrant substance and spray droplet evaporation. A typical question is like:
A HFA-134a liquid is preserved in pressurized container, and is injected through nozzle to room condition (1atm, 25C). Ignore the spray breakup effect. The droplets then suffer from high rate evaporation.
So my question is, suppose the evaporation time is long enough and air has zero HFA-134a, what is the eventual droplet equlibrium temperature (wet bulb temperature)?
What confuses me is, HFA-134a has its boling point around -30C at 1atm much lower than room temperature? So any way (equation?book?paper?) to calculate this wet bulb? Make necessary assumptions if you need, I guess I only need an answer under the simplest situation.
Thank you very much.
