Question about Theory.
Mohamedsayed
61
Hello
I need to know what is the difference between modeling a material for instance concrete as elastic-plastic with strain softening and model the same material (concrete) using damage plasticity approach.
Although In elastic-plastic with strain softening, the post peak failure is included, there is no degradation of the stiffness, right?
I wish someone explain the difference between them.
Thanks.
What are you modeling that this question is necessary to ask?
Mike McCann
MMC Engineering
I am working on Rock, The rock is similar to concrete in its behavior, usually it is brittle or quasi-brittle.
I know that the softening of material can be simulated in the elastic-plastic criterion. I asked my self, what is the difference between concrete damage plasticity and elastic-plastic with softening.
