HassanZebari
Hello fellow engineers,
I have a 4m*15m slab with beams cast together on four sides and supported by a bearing wall..Can we consider the slab as one way slab?
Is the slab simply supported or cont.from two edges due to stiffness between slab and beam so we can find its thickness using equations according to deflection requirements?
Also, How can we classify the beam support on bearing walls (length of span and ends supports) to find bending moment and torsion on beam?
