righttirefire
Automotive
This subject was touched earlier, but why can't you make a cam that spins 1/4 the rotation of the crank. I'm aware the it would have two lobes. If you took a SB chevy cam, for example, ground one with half the angle of the origanl base circle and created two lobes, on opposing sides of tha base circle. Therefore the the cam is spinning half the speed of a normal cam, the duration would remain the same. I heard Buzz Schaller invented one, It was origanlly for Harley-Davidsons, and adopted into a Chevy Mickey Thopmson used in a indy car. Is it possible to ground one, if so why aren't they popular? It seems to me it would be more efficent, it would spin slower so higher rpms could be reached quicker, and there would be less friction which should directly effect horsepower and torque.
