I agree with MadMango. In a note, point to a spec or internal process spec, but do not spell out the process on the dwg.
For a PCB, trimming pots or similar is acceptable, it is part of the process of mfg the part.
Test processes change and should not be spelled out. Also, if too many processes are spelled out in a note, the machinist or whoever is making the part, will quote to do all processes in addition to making the part.
In my experience with aerospace/military industries, Key/Critical Characteristic callouts are required most of the time to verify the part will fit according to customer specs and interface dwgs. These callouts are referenced to/from QA docs that is configuration controlled with the customer.
As Markn82 and Heckler pointed out, do not list revisions with specs on dwgs either. The only dwgs I have ever the need to list revisions is military dwgs that are owned/controlled by the military or their main supplier (our customer).
Also, a lot of companies have proprietary dwgs that are not seen by their customers. But, during an audit, the customer may ask to see test procedures (or any procedure) to insure them they are getting a quality product. Usually these procedures are given to the customer to review. If listed on the dwg, they do not have the dwg to review.
Drawings should be controlled by Engineering, Drafting and/or Design depts; quality docs/test proc/etc controlled by Quality.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP3.1 / PDMWorks 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
