A subcritical PWHT is typically used for most materials, and is qualified as such with a WPS. On occasion where re-heat treatment is desired to eliminate the weld heat affected zone in base materials or is required as weldstan mentioned, this operation can be performed. However, as a cautionary note, complete re-heat treatment may result in unwanted distortion.
