Forgot2Yield
Industrial
I am designing a canopy structure, and it is located in between two buildings. Currently, this area where the foundation is supposed to go is right in the path for water runoff. The ground water for this site is also close to the surface.
I am wondering if anyone has used pipe through a footing before to allow drainage through the foundation?
I am planning on putting the foundations a few feet under ground and adding some pedestals so that any water can flow above and below the footing. But even If I do this I feel like maybe the pipe through the foundation would still be necessary?
