rockman7892
I was in a facility the other day which had two identical 900kW generators at 4.16kV. I noticed above each generator there was what appeard to be a fixed resistor bank hanging from the ceiling of the room with each resisotr bank appearing to be connected to the generator output terminal box.
I was hoping that someone could explain to me the purpose for these resistor banks? I know resistor banks are used for load testing of generators but I find it hard to believe these resistor banks would be permenantly installed for such testing.
I was thinking the resistors could be either:
A) Some means of controlling real/reactive output from generator
or
B) A means of dumping regenerative or reverse power fed to the generator from the system similar to a braking resistor in a VFD?
Can someone please help explain the purpose of such resistor banks in this generator application?
or
