Purge Doesn’t work
  • Thread starter Thread starter RioT
  • Start date Start date
R
RioT
Guest
Hi Guys,
I used Proe WF2 with windiws xp and I have had any problem untill I installed Windows 7.
Now, in windows 7, I the file purge.bat doesn't work and I have all my working directory full of old files
In windows Xp I simply ran purge.bat on My working directory with dobble click but Now I tried without results.
Can you help me please
Thankyou very much for your answers
Does it maybe work, if you use RMB and then choose Run as administrator?
Regards, DonChunior
What RMB is?
In windows Xp I copied purge.bat in my working directory and I ran It but now he same thing doesn't work.
I tried to "pause" the path in the purge.bat file and the result is the message
'x86e_win64_ptc_setvars' is not recognized as an internal or external command, operable program or batch file.
'ptc_setvars.bat' is not recognized as an internal or external command, operable program or batch file.
Could not find D:\Work\ptc_setvars.bat
The system cannot find the path specified
I have not any solution in my mind!
RMB = Right Mouse Button
Add the directory bin of your Pro/E installation to your system environment variable PATH.
Regards, DonChunior
Regards, DonChunior
And How can I do this in windows7?
Thank you very much for you answers!
OK, I've done what you said but purge doesn't work yet
At least the message regarding to the unrecognized command shouldn't show up any more, right?
Is there any new error message?
The error message is the same
The purge.bat should be run from the bin directory. Otherwise you may need to set the environment variable PRO_DIRECTORY.
I always use the Spekan Purge Tool.
You can download from many sites. This is one: http://www.prousercarolinas.org/tips/utilities.htm
In that same directory I just found CGN Purge. Seems like a nice purge tool too.
Edited by: EddyVE
Open the folder you files are in using windows explorer.
Hold shift down and right mouse click.
Select open command window here.
Type in purge.
This will purge the older files.
Type in purge.
Nice tip, too bad my windoze 7 install gives me this error message from explorer.EXE:
"This file does not have a program associated with it for performing this action."
Nice one Mr. Bill.
dr_gallup said:
Nice one Mr. Bill.
Wait 'till you see what they did with Windows 8 .... Thatlooks like amonster unfit for anythingexcept reading e-books...
(sorry for being off-topic)
The problem does not exist anymore.
I changed all purge.bat file like below
@echo off
set start_cmd=start ""
"C:\"Proe directory"\i486_nt\obj\purge.exe" %1 %2 %3 %4 %5
:ptc_end
echo Done!
pause
exit /B %ERRORLEVEL%
and now purge run so good!
Thanks a lot for all the answers. Enjoy
However I doubt the issue you faced is bacuse you were using a 32bit Pro/E on 64 bit OS and by default most of the options do not work if 32 bit s/w is executed on 64 bit OS???
