Hokie,
You’re not that idiosyncratic. Not only do I like to be able to adjust d for chairs/blocks (have to say I prefer the concrete blocks to chairs for bottom steel), but I also like to be able to adjust it for external/internal applications. Then there is out of sequence cantilevers, and steps to account and I’m not even going to start with beams/PT…….It really annoys me when for a program all you can input is one cover and you have 5 different covers.
As for punching shear, in flat plates/slabs, I not only like to account for column stiffness, but I also like to account for column projection, every single project has a projection these days and if you don't catch it early in the formwork laying, I can guarantee you it is a pain in the royal ass after the steel has been laid.
The column stiffness I like to select is based on axial load there are some good articles around, however I have found the NZS code a good guide for this purpose. It would suit my purposes if software allowed you to spec different stiffness for different applications, ie I would like to be able to set the column stiffness conservatively for slab bending and conservatively for punching shear. As these are complete opposites in return value, and column stiffness from all the reports I have read are all over the place, best estimate is +/- 30%.
Rapt,
While software developers cannot be hold fully responsible for the degradation of engineering in regards to use of software. It can be held responsible for Poor manuals (I will exclude Rapt Manual from this statement which is about 60% better than most other manuals). Most software developer these days fail to convey what theories or fundamentals their software is using, mainly only suppling manuals with directions on how to input the parameters, which is normally only about 2% of the parameters used in the process. I want to be able to control the parameters used in every step of the process, from column stiffness to code controlled values.
I also dislike software’s that select shear steel for punching instead of highlighting the problem, for using arrangement of shear steel in beams that is unrealistic. I say this from a checking engineer’s point of view, for junior engineers to learn they need to be able to do their own projects, and will get lost from time to time in the local practices. In north qld it is rare to use shear steel in thin slabs for punching shear, with drop panels being the norm. It would be good if the software made them select an input or direction, as so that this problem is highlighted to the supervising engineer, instead of the poor supervising engineer having to sort thru 28 pages of program output to find the error.
ok time to get off the soap box and have a beer.
An expert is a man who has made all the mistakes which can be made in a very narrow field
