Hello everyone,
I hope you are all doing well.
I have a situation where I am trying to transfer cleaning water between two tanks. Currently I manually turn the pump on and monitoring the level in the tank being emptied. When the tank is completely empty I turn off the pump and isolate the tanks. The tanks are both less than 500L.
I would like to automate this process and as usual, it has to be as cheap as possible. The pump is a small, 1HP, centrifugal pump. For reliability I would prefer to use a flowswitch in the drain line of the tank being emptied, but I'm curious if I could use the power draw on the pump to trigger shutting off the pump. I think that may be a cheaper option.
I am concerned that the power load will not change significantly when the flow goes to zero. I have come across a few web pages that indicate the same, but I would like to get additional feedback from people more knowledgeable then I about pump operations.
Does anyone have any experience using the power draw to indicate dry running?
I'm also curious if I able to use the pump curves at the zero flow condition to determine the expected power flow at this condition?
Please let me know if any additional information would be helpful.
Cheers,
Macmet
Cheers,
Macmet
