SPSUEngineer
Here's the deal. I'm the civil site engineer on a school addition with an existing septic system we want to use.
The architect wishes to lower the floor elevation of the new addition and that means the sanitary invert will be lower than the existing septic tank I need to tie into. I can't lower the tank elevation because it is already as low as it can be for the nitrification fields.
Can I install a pump station before the septic tank and pump effluent into it? I could design the force main to keep the velocity low (+/-2.5 ft/sec). I don't have much expertise in this area. I've searched the code and a few textbooks but can't find an answer to this. It seems to me that a grinder pump would create a "slurry" and the tank wouldn't be able to do its job of separating solids from liquids. Is this correct or am I overthinking it?
I'm trying to do this without installing an additional tank if possible. I have a situation where I can't increase the capacity of the existing system without bringing it up to code and I don't have the land area available.
This is in the State of Georgia and under the jurisdiction of the EPD (flow rate over 10,000 GPD) if anyone knows of a code issue.
Thanks!!
Thanks!!
