PUMP ROOM PUMP PLACEMENT PROBLEM
rahulishere
7
Hi..
There is a problem in my site were im working.... the pump room has no enough space as the pumps are horizontal flow pumps...my question is that can we arrange pumps in any order ....means normally they are parrallel and symmetrical placed...can i arrange thm in my own way ( means vertically and horzontally ) so that thy could fit in the room properly.... Is ther any pblm by doing so ??
Yes, there are problems turning a horizontal pump to vertical.
Best bet: talk to the engineer who did the design.
Second best: Wait for a pump fellow to answer.
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
hi Gober Dave ,
I didnt meant to turn the horizontal pump to vertical i just asked if u could arannge the pumps in any way means not parallelly...can we arrange them perpendicular so any fashion tht would fit in room. Please advice.
Thank You.
Rahul.
Without seeing the original design next to your new layout, I don't think anyone will be able to comment directly to your question.
Do you have access to the designer? That's the best place to start. If not, make us some sketches.
Best to you,
Goober Dave
if you place balancing valve on one of pump connection, you can connect it in non-symmetric fashion.
The only reason for pumps or other equipment to be arranged with their axes parallel to each other, other than aesthetics, is for ease of maintenance. In many existing spaces that have been retrofitted, it is common to see them scattered around whatever space is available.
