devaxrayz
Chemical
- Feb 8, 2004
- 61
Hi all,
I am in a work of sizing pump and its pipeline. The pump discharge has 2" nozzle and the pipe sizing is 6" diameter. Which should i use :
1) Either 2" block valve, 2" check valve and then expand the line to 6" diameter or,
2) expand the line to 6" diameter and use 6" block valve and 6" check valve.
Why?
Thanx for your help...
-Rayz-
Why?
-Rayz-
